https://help.awsstgqa.tallysolutions.com/docs/te9rel66/Tax_India/excise-mfg/em-return-tran-er8.htm
Return Transaction Book for Form ER 8 (Excise for Manufacturer)
The Return Transaction Book displays the list of Saved Returns. Each time the excise forms are modified.
To view the Return Transaction Book
1. Go to Gateway of Tally > Display > Statutory Reports > Excise Reports > Manufacturer.
2. Click Return Transaction Book .
3. Press Enter to go to the return form.
