https://help.awsstgqa.tallysolutions.com/docs/te9rel66/Reports/Display_Inventory_Reports/Movement_Analysis.htm
Movement Analysis
Movement analysis shows the analysis of only those inventory transactions which are integrated with the accounts, i.e. inventories which are also recorded in the books of accounts. Inventory vouchers which affect the stock only in quantitative terms are not considered.
Movement analysis report is used for comparative studies. They give an insight into the flow characteristics of the stock in an organization. It also helps in finding out the slow moving items which cause blockages in the flow of the working capital of the organization.
● Go to Gateway of Tally > Display > Inventory Books > Movement Analysis .
Movement Analysis Reports show only those inventory transactions for which accounting transactions have also been recorded. You can analyze stock movements by stock groups, categories, financial group or ledger.
To know more, click the links below:
● Stock Group Analysis
● Stock Category Analysis
● Stock Item Analysis
● Group Analysis
● Ledger Analysis
● Transfer Analysis
