https://help.awsstgqa.tallysolutions.com/docs/te9rel66/Payroll/employee_breakup_of_pay_head.htm
Employee Breakup of Pay Head (Payroll)
You can view the Summary employee-wise breakup of the Computation for the required Pay Head from the Payroll Reports or Statutory Reports .
V iew Employee Breakup of Pay Head report
B utton options in Employee Breakup of Pay Head report
View Employee Breakup of Pay Head report
1. Go to Gateway of Tally > Display > Payroll Reports > Statutory Reports > Summary .
Or
2. Go to Gateway of Tally > Display > Statutory Reports > Payroll Reports > Summary .
3. Press Enter on the required Pay Head Type.
4. Press Enter on the required Pay Head.
The user can drill down to a corresponding Employee Voucher from the above report.
Button options in Employee Breakup of Pay Head report
● F2: Period : Click F2: Period to change the selected period.
● F12: Configure : Click F12: Configure show/hide the Employee Number .
