https://help.awsstgqa.tallysolutions.com/docs/te9rel65/Tax_India/tds/configurations-in-tds-masters.htm
Configurations in Masters for TDS
You can enable advance configurations for TDS in party masters. This will allow you to configure surcharge exemption limits, and income exemption limits. You can also set a zero or lower rate of TDS for party masters.
Ignore surcharge exemption limit
Ignore income tax exemption limit
Set zero/lower rate for TDS
