https://help.awsstgqa.tallysolutions.com/docs/te9rel65/Maintaining_Company_Data/F11_Features/F3_Statutory_Taxation.htm
Statutory and Taxation Features
Tally.ERP 9 supports the various taxes applicable in India. You can maintain accurate books of accounts and generate error-free returns by detecting the missing information in the transactions, if any, and correct them before filing returns.
You can use statutory and taxation features in Tally.ERP 9 by enabling the required options in the Company Operations Alteration screen.
To enable statutory and taxation features
1. Go to Gateway of Tally > F11: Features > F3: Statutory .
2. Enable the required options in the Company Operation Alteration screen as shown below:
