https://help.awsstgqa.tallysolutions.com/docs/te9rel65/Tax_India/VAT/vat_purchases/pur_zero_rated.htm
Zero Rated Purchases (VAT)
You can record purchases of zero rated goods by selecting the nature of transaction Purchase - Zero Rated .
This nature of transaction is provided for Andhra Pradesh, Assam, Goa, Gujarat, Haryana, Himachal Pradesh, Jharkhand, Jammu & Kashmir, Kerala, Ladakh, Madhya Pradesh, Maharashtra, Odisha, Puducherry, Tamil Nadu, Telangana, and Uttarakhand.
To record an invoice for zero rated purchases
2. Enter the Supplier invoice no. and Date .
4. Select the purchase ledger grouped under Purchase Accounts with the Nature of transaction set to Purchase - Zero Rated by selecting the required Party Entity/Org. Type .
5. Select the required stock item. Enter the Quantity and Rate .
6. Set the option Provide VAT Details? to Yes . In the Statutory Details screen.
o Select the Form to issue as shown below:
Note: The options in the above screen appear based on the State selected in the Company VAT Details screen.
o Enter the other relevant details.
o Press Enter to save and return to the purchase invoice.
7. Press Enter to save.
