https://help.awsstgqa.tallysolutions.com/docs/te9rel65/Data_Management/Export_of_Data_Intro.htm
Exporting Data
Data can be exported from Tally.ERP 9 for many reasons such as for use in a third-party application, for filing returns, and so on.
You can export data in 6 different formats:
● ASCII (Comma delimited)
● Excel (Spreadsheet)
● HTML (web-publishing)
● JPEG (Image)
● PDF (Portable Document Format)
● XML (data interchange)
Click the following links for more information:
Export Formats
Exporting Masters
Exporting Vouchers
Exporting Reports
