https://help.awsstgqa.tallysolutions.com/docs/te9rel65/Job_Work/Job_Work_In_TallyERP_9.htm
Job Work in Tally.ERP 9
Tally.ERP 9’s simple yet powerful Job Work feature enables you to record transactions related to Job Work with ease. The Job work functionality in Tally.ERP 9 has the following features:
● Simple and user-friendly
● Quick and easy to set up and use
● Job Work Out Process
o Record Job Work Out Order by capturing the details of Components to be issued and Finished Goods /Scrap to be issued
o Account the Receipt of Components towards a Job order or directly record the Material receipt by creating the Job Order.
o Flexibility to account the Receipt of Finished goods without raising Job Work Out Order and Material In voucher
o Track cost against the Job Work Out Orders
● Job Work In Process
o Record Job Work In Order by capturing the details of Components to be received and Finished Goods /Scrap to be delivered
o Flexibility to account the delivery of Finished goods without raising Job Work Out Order and Material In voucher
o Track the Own Consumption of Goods against the Job Orders and Bill the same on the Principal manufacturer
● Generate Annexure II for Removal of Goods for Job Work
● Maintain and Generate Annexure IV (by Principal Manufacturer - if excise applicable)
● Maintain & generate Annexure V (By Job Worker - if excise applicable)
● Reports
o Generate Order Outstandings report for Orders & Components
o Generate Job Work Registers such as Job Work Out Order/Job Work In Order
o Material Out Registers
o Material In Registers
● Material movement Register
o Provision to view the details of Stock lying with the Job worker and ageing of the stock
o Provision to generate the report to analyse the variance in issue of components and receipt of finished goods and vice versa.
