https://help.awsstgqa.tallysolutions.com/docs/te9rel65/Data_Management/DM_Upload_Reports_Generated.htm
Uploading Reports from Tally.ERP 9 to a Web Page
You can upload your financial reports to your website directly from Tally.ERP 9.
To upload reports from Tally.ERP 9 to a web page
1. Click O : Upload in the required report.
2. Select Web Page (HTTP/HTTPS) in the field Upload to .
3. Enter the URL .
4. Set the option Secure Server? to Yes , if required.
5. Enter User Name .
6. Enter Password .
Note: Reports can be uploaded without entering a user name and password if the web page server accepts anonymous connections.
7. Select the required Format .
8. Enable, disable or select additional configurations if required.
The upload report screen appears as shown below:
9. Press Enter to upload the report to the web page.
See Also
Uploading Reports from Tally.ERP 9 to an FTP Location
Uploading Vouchers from Tally.ERP 9 to a Web Page
Uploading Vouchers from Tally.ERP 9 to an FTP Location
