https://help.awsstgqa.tallysolutions.com/docs/te9rel65/Data_Management/Connectivity_and_Compatibility_with_TS9.htm
Connectivity and compatibility in Tally.Server 9 Environment
Tally.Server 9 needs to be connected to the Internet for smooth operations which include user authentication and license management.
Connectivity
If Tally.Server 9 has not been connected to the Internet for 30 days , in the List of Tally.Servers in Tally.ERP 9, information on the number of days till surrender will be displayed ( Will be Surrendered after x day(s) ):
Users need to ensure that Tally.Server 9 is connected to the Internet to avoid License Surrender.
Incompatible version of Tally.Server 9 used with Tally.ERP 9
Tally.ERP 9 Series A Release 4.51 or a higher release will crash with the following error message if Tally.Server 9 Release 4.5 is used for data sharing:
Users need to upgrade to a higher release of Tally.Server 9 to continue working on Tally.Server 9 data.
Incompatible version of License Server
The following message will be displayed in Tally.ERP 9 Series A Release 4.5 if Tally.Server 9 Release 4.51 or a ย higher release is used alongside License Server 7.8 :
Users need to upgrade to License Server 7.9 for smooth operations.
Incompatible version of Tally.Server 9 used with License Server 7.9
The following error message will be displayed in Tally.ERP 9 if Tally.Server 9 Release 4.5 is used alongside License Server 7.9 :
Users need to upgrade to a higher release of Tally.Server 9 for smooth operations.
