https://help.awsstgqa.tallysolutions.com/docs/td9rel54/td9/working_with_projects/saving_projects.htm
Saving Projects
In Tally.Developer 9, you can save the current file either in the existing format or a different format, or save all open files in the project.
To save a file
● Go to File > Save File .
The file is saved in the current file, in the existing format.
● Select Save File As to save another copy of the existing file with a different name, and at a different location. The new file will become the current file in the active window.
● Select Save All Files to save all theΒ files open in the Project browser window.
● Click S ave File , or Save All Files to save a file or all files within the project. These options are also available on the standard tool bar.
