https://help.awsstgqa.tallysolutions.com/docs/td9rel54/td9/working_with_projects/executing_projects.htm
Executing Projects
For executing Tally from Tally.Developer 9 , the parameters need to be set in Preferences . Click here for more details.
To execute Tally.ERP 9 Β from Tally.Developer 9
● Go to Build > Execute Tally , or press Ctrl+F5 .
or
● R ight-click the project in the project explorer window, and click Execute Tally .
To list syntax errors in the code
● Go to Build > List Syntax Errors .
The syntax errors found in the current project are displayed in the Build tab of the Output window.
