https://help.awsstgqa.tallysolutions.com/docs/td9rel54/td9/tally_developer_tools/td9_tools.htm
Tally.Developer 9 Tools
Tally.Developer 9 comes with built-in tools which are explained in this topic.
● Tally Connector
● Dictionary Manager
● Tally.NET Auth Library SDK
● Manage Customer Serials
● Import and Export of Customer Serials
● Preferences
The Tools menu appears as shown below:
Note: To decompile TCP, select the option Utilities > TCP Decompilation from the Tally website using the account login and password.
