https://help.awsstgqa.tallysolutions.com/docs/td9rel54/td9/using_output_window/using_the_output_window.htm
Using the Output window
The Output Window contains five tabs namely, Output, Build, Search, Reference and Command . The Output window can be hidden or displayed using the short cut Alt + 2 or by selecting Show/Hide Output Window option from View menu.
The default selection of Output Tab appears like the following:
