https://help.awsstgqa.tallysolutions.com/docs/td9rel54/dict-mgr/using-reference-dictionary/adding_strings.htm
Working on Reference Dictionary
Using Reference Dictionary you can add strings, search and edit strings, and also add translations.
Reference dictionary enables the following actions:
● Adding Strings
● Adding Translation
● Searching Strings
● Editing Strings
Adding Strings
When Dictionary Manager creates a reference dictionary, all single word strings that are translated, are available in it. Strings can be further added into the reference dictionary, when required.
To add strings into the reference dictionary
1. Click an empty row in the column English .
2. Enter the string to be translated.
3. Press Enter or Tab key from the keyboard to add the string.
Adding Translation
The translation can be edited and added for the strings by clicking in the column for the translated string (the language column).
To add translation
1. Click the language column next to the word.
2. Enter the translation. To use the phonetic key board, go to Edit > Phonetic Keyboard .
3. Press Enter or Tab key from the keyboard to add translation.
Searching Strings
To search for a string in the reference dictionary
1. Enter the string to be searched for, in the Look For: field.
2. Select appropriate option from the In drop down box.
3. The reference dictionary will display the search results.
Editing Strings
To alter a string
● Click in the required column.
● Edit the required string.
