https://help.awsstgqa.tallysolutions.com/docs/td9rel54/td9/using_language_browsers/using_language_browser.htm
Using the Language Browsers
Tally.Developer 9 has different browser windows.
● Project Browser
● Definition Browser
● Function Browser
● Action Browser
● Schema Browser
All the details in each browser window are displayed in a tree-like structure.
These browsers allow the user to explore the object structure and attributes of definitions. With these, the application developer will be able to develop the code rapidly and effectively.
