Undo the Extension of e-Way Bill Validity in TallyPrime
In TallyPrime, you can extend the validity an active e-Way Bill if the delivery is delayed due to any unforeseen issues. However, if the situation improves and the goods are delivered on time, you may not require the extension. In such cases, TallyPrime allows you to undo the extension, removing the updated validity details and restoring the e-Way Bill to its original status.
  1. In the e-Way Bill report, drill down from the relevant section in the e-Way Bill report; for example, the Pending for e-Way Bill extension screen.
  2. Select the voucher and press Alt+F10 (Undo Extension).
  3. Select Yes to proceed.
    This will remove details of the extension (such as the Reason for extension and Remarks), and the voucher will move to its original section.
With TallyPrime, you can easily undo the extensions of e-Way Bills when they are no longer needed, ensuring accurate tracking and up-to-date records.
