Reasons for Rejection of e-Invoice and Resolutions
NIC has published the following error codes, error message, the reasons for the errors and the corresponding resolutions to help you resolve errors faced during e-Invoice upload to the NIC portal.
If the error message is not available here, check the page published by NIC https://einv-apisandbox.nic.in/api-error-codes-list.html
.highlight { font-weight: bold; background-color: rgb(248, 233, 150); } #searchInput { border: 2px solid #CCE0F4; border-radius: 5px; font-size: 14px; width: 50%; } .searchContainerScroll { background-color: white; position: fixed; top: 70px; box-shadow: 0px 2px 5px rgba(0, 0, 0, 0.1); padding: 15px 15px 5px 15px; transition: top 1s; } .searchContainer { width: 100%; min-width: 300px; background-color: white; padding: 15px 15px 5px 0px; top: -10px; }
Most Frequent Errors/Rejections
Understanding Rejection Terms: TallyPrime vs e-Invoice
As the rejection messages are based on GSTIN, the terminologies in TallyPrime vary in some instances. Hence, we have provided a table to facilitate a better understanding between TallyPrime and e-Invoice terminology.
e-Invoice Terminology TallyPrimeTerminology Length
Field Location Bill from place (earlier to Release 2.1) & Invoice bill from place (Release 3.0 and later) – F11:Company Feature 3 to 50 (Alpha)
Field Document Number Invoice Number / Voucher Number
16 (Alpha-Numeric) with / or –
The voucher number must not:
  • Start with 0
  • Contain any spaces
  • Include special characters other than / or –
  • Be blank
State Field is Required For all Invoices – its company State field (F11:Company Features> Enable Goods and Services Tax (GST) > Bill from place (earlier to Release 2.1) & Invoice bill from place (Release 3.0 and later)
For specific Invoice – its Party (Party Details / Consignee Details using Ctrl+I (More Details or Dispatch From Details section under e-Invoice Details using Ctrl+I (More Details)
Field Address 1/Field Address 2
For All invoices – its company addresses
For specific Invoices – Its Party master – Check ledger master or party details for buyer and consignee – 1st Line / 2 refers to 2nd line
Address 1 – 1 to 100 (Alpha Numeric)
Address 2 – 3 to 100 (Alpha Numeric)
Field Legal Name
For all transactions – its company: Mailing Name
Go to Company Alteration > Mailing Name
For specific Invoice – Its Party: Mailing Name
Go to Party alteration > Mailing Name
Field Product Description Stock Item name 3 to 100 (Alpha Numeric)
Field POS  Place of Supply – In party details/supplementary details check Place of Supply
Recipient Pin Code Buyer PIN code – Check party master or party details screens with PIN code 6 digits
Recipient should be SEZ Buyer details – Registration type should be SEZ
State code does not match For All Transactions – State name is not selected in the list in F11:Company Features > State – select the details from list
For specific Invoices – State name is not selected properly in Party details / Place of supply
GSTIN is inactive or cancelled Verify GSTIN status / If cancelled or inactive Registration type should be Unregister
Error Message/Scenario  Reason for Error Resolution
Duplicate IRN
You might be attempting to create an IRN that is already generated.
When trying to generate an e-invoice, you will receive a duplicate IRN if the IRN number has already been generated, cancelled, and repassed with another entry in the same cancelled voucher or with a previous voucher number with a new invoice.
Say for Voucher No 1, you have generated an e-invoice, which you have cancelled later. If you are now generating an e-invoice for another voucher with the same voucher number, you will be prompted with a duplicate IRN error.
In this case, record the new voucher with a separate voucher number. Also, remove the IRN from the e-invoice details and then generate the e-invoice through the new voucher.
  • In case the IRN/QR code does not exist for the said invoice, then instead of re-generating, you can use “Get IRN”. If not done within 72 hours, then this solution works.
  • In case voucher is deleted by any chance, and due to numbering it is showing, then we need to recommend not to delete voucher and insert same voucher and use get IRN and in case it greater than 72 hours then raise credit note.
The field Address 1 must be a string with a minimum length of 1 and maximum length of 100 Address 1/Address 2 is not as per the required format
The maximum length of address allowed is 200 characters (100 against address line 1 and 100 against address line 2). Tally will combine and incorporate the maximum possible characters in first and second address lines (after truncating to nearest word). However, if address is beyond 200 characters it will get rejected by NIC. Hence ensure the Party masters and Company dispatch address and in accordance with this. Please remove any additional information (Ex: Contact person name / phone / e-mail etc. mentioned as part of address.) that is not relevant or is not a property of address.
The field Address 2 must be a string with a minimum length of 3 and maximum length of 100
GSTIN is inactive or cancelled GSTIN is inactive or cancelled by department or tax payer.
Check if the GSTN is correct. If yes, click the Sync GSTIN from GST CP API.
  1. To verify, go to the einvocie1.gst.gov.in portal > click Search > Taxpayer/GSTN.
  2. Mention the GSTIN and Captcha > click Go.
    This displays the GSTN details.
  3. Click the Update from GST Common portal.
    The portal displays the updated status.
If you get the status as Active, then you can restart your request to generate the IRN.
However, if GSTIN is still inactive due to business closure, you can change the said transactions as Sales to Unregistered/Consumer so that such transactions can participate in B2C table.
Invalid GSTIN GSTIN provided is incorrect
Provide the correct GSTIN
Verify the GSTIN using below link
https://services.gst.gov.in/services/searchtp
The State field is required State code is not specified
State code refers to the State selected under F11 (Company Features) or in the ledger of the party for which the invoice is recorded. When you do not specify the State, you will not be be able to generate an e-Invoice.
You can check the State on the following paths:
  • F11 (Company Feature) > Enable Goods and Service Tax (GST) > GST Details.
  • Press Alt+G (Go To) > Alter Master > Ledger > type or select the name of the Ledger for which the invoice is recorded, and press Enter.
Here’s how to resolve the error in such vouchers.
If you are using TallyPrime Release 3.0 and later, then follow the steps given below:
  1. Identify the vouchers.
    1. Press Alt+G (Go To), type or select e-Invoice, and press Enter.
    2. Drill down from the Information required for e-Invoice not provided section, and you will find the vouchers.
  2. As per the master in which the State is incorrect:
    Press F11 (Company Features) > set Enable Goods and Services Tax (GST) to Yes, and specify the correct State.
    Or
    Press Alt+G (Go To) > Alter Master > Ledger > type or select the name of the Ledger for which the invoice is recorded and press Enter, and specify the correct State.
  3. Generate e-Invoice for the vouchers.
    2. Drill down from the Information required for e-Invoice not provided section.
    3. Open the voucher and generate e-Invoice.
If you are using TallyPrime Release 2.1 and earlier, then the vouchers will be found in the Mismatch due to tax amount modified in voucher section. You need to ensure that the State is selected under F11 (Company Features) and the ledger created for the party.
The field unit must be a string with a minimum length of 3 and a maximum length of 8. This error occurs when the UQC is not selected in the Stock Item master.
When you create or alter Stock Items, ensure that for given Unit of Measurement – UQC (Unit Quantity Code) is selected.
Once you select the UQC in the stock item and save it, you can generate e-Invoices.
The field Location must be a string with a minimum length of 3 and a maximum length of 50
Location is not as per the required format
The field Location refers to the Invoice bill from place set under the GST Details of the F11 (Company Features). You can check it on the following path:
If the Invoice bill from place is lesser than 3 characters or greater than 50 characters, then the vouchers get rejected by the e-Invoice system.
    2. Drill down from the Rejected by e-Invoice System section, and identify the vouchers with the Reason for Rejection.
  2. Specify the Invoice bill from place.
    1. Press F11 (Company Features) > set Enable Goods and Services Tax (GST) to Yes.
    2. Invoice bill from place: Specify the name of the location you want to use for billing.
      Ensure that the name consists of minimum 3 characters and a maximum of 50 characters
    2. Drill down from the Rejected by e-Invoice System section.
    3. Open the voucher and generate the e-Invoice.
If you are using TallyPrime Release 2.1 and earlier, then the vouchers will be found in the Missing/Invalid Information section. You need to ensure that Invoice bill from place is specified in the required format.
6 digit HSN code is mandatory for taxpayers with greater than or equal to 5 Cr
The e-invoice system for the Goods and Services Tax (GST) has been revised for taxpayers with an Annual Aggregate Turnover (AATO) of Rs. 5 crores and above. At least 6 digit HSN is mandatory in e-invoices for such taxpayers from the 15th of December 2023
You can resolve this rejection by updating the stock item or ledger with the correct HSN/SAC details.
If the the HSN/SAC is starting with the 01 to 98 chapter, ensure that the Type of supply is configured as Goods, and if the chapter is 99 then Services, with proper applicability date.
Update transactions Ledger-wise or Stock Item-wise
  1. Press Alt+G (Go To) > Alter Master > Stock Item.
  2. Select the stock item to be updated and press Enter.
  3. Update the HSN/SAC under HSN/SAC & Related Details.
Once you have updated the HSN/SAC, go to the e-Invoice report to mark the rejected transactions as resolved and try resending the request.
  1. Press Alt+G (Go To) > e-Invoice > and drill down from Rejected by e-Invoice Systems.
  2.  Press Alt+R (Mark as Resolved) to resolve the transaction. After being resolved, the transaction will appear under Pending > For IRN Generation.
The field rounding off amount must be between 99 and -99
Reason1 : Ledger type is selected as “Invoice Rounding” in expenses, sales ledger or duty ledger, selected under expenses or sales, where enabled the option invoice rounding and accepted, later changed to the duty ledger.
Reason2 : This error even occurs in vouchers, where round-off is not used. The reason for this could be in any of the ledgers used in the invoice type of ledger would have been chosen as Invoice rounding. This could be in the party, sales, or additional ledger
Reason1
Alter the expense and sales ledger
  • Set the Type of Ledger option to Not Applicable.
Alter the duty ledger
  1. Set Type of Ledger to Not Applicable.
  2. Press Backspace > select Duties & Taxes and press Ctrl+A to accept accept the ledger and transaction.
Reason2
  • We suggest changing the accounting group to Expenses, then Set the Type of Ledger option to Not Applicable.
The field document number must match the expression'((a-zA-Z1-9)(1)(a-zA-Z0-9/-)(0,15))$’
(or)
The document number doesn’t match with regular expression
Document Number is not as per the required format
Document Number references to the Voucher No. enter during voucher creation. A Document Number must fulfill the following criteria:
  1. Cannot be empty
  2. Should be maximum 16 characters
  3. Should not have space
  4. The only special character allowed is / (forward slash)
  5. The first character should not be 0 or / (forward slash)
  2. Drill down from the Uncertain Transactions (Corrections needed) section.
  3. Open the voucher, enter the correct document number, and generate the e-Invoice.
If you are using TallyPrime Release 2.1 and earlier, then the vouchers will be found in the Information required for e-Invoice not provided section. You need to ensure that the document number is correct.
The field Assessable Amount (Total Amount – Discount) must match the regular expression ^\d+.?\d{0,2}$.
The field Assessable Amount (Total Amount – Discount) must be between 0 and 999999999999.99.
This error occurs if the discount ledger is configured under the Sales Account, with:
  • Type of Ledger as Discount.
  • GST applicability enabled.
  1. Press Alt+G (Go To) > type or select e-Invoice > press Enter.
  2. In the e-Invoice report, select Rejected by e-Invoice System and press Enter.
  3. Drill down to the transaction with reason for rejection as the field Assessable value must be a positive value.
    field-assessable-amount
  4. Update the discount ledger in the transaction.
    1. Select the discount ledger and press Ctrl+Enter to open it in the alteration mode.
    2. Under: Select Indirect Expenses from the List of Groups.
    3. Type of Ledger: Not Applicable.
    4. Include in Assessable Value calculation for: GST.
      1. Appropriate to: Goods
      2. Method of Calculation: Based on Value
    5. Press Ctrl+A to save the ledger.
      based-on-value
  5. In the e-Invoice – Voucher Register, drill down to the transaction and press Ctrl+A to save.
    e-invoice-confirmation
  6. When prompted, press Y or Enter to generate e-Invoice for the transaction and enter your e-Invoice credentials.
The e-Invoice gets generated. The voucher also gets updated with the Ack no. and IRN.
Reason2 : This error even occurs in vouchers, where round-off is not used. The reason for this could be in any of the ledgers used in the invoice type of ledger would have been chosen as Invoice rounding. This could be in the party, sales, or additional ledger.
Reason1
Reason2
The field Product Description must be a String with a minimum length of 3 and the maximum length of 300
The Stock item name is not as per the required format
Stock item Name is the product, which is dealt with for any Business, ensure the stock item Name provided should hold Min 3 to max 100 characters.
Recipient cannot be SEZ for – {0} transaction
SEZ GSTIN has been passed as GSTIN in Recipient details for the specified type of transaction
Only the Registration type is configured as Regular, however, its being SEZ party – party type should be configured ie., in the party master alteration > enable set/alter GST details > Under Party type select “SEZ”
The document date should not be future date.
This error occurs if you have recorded an invoice for a future date and are trying to generate an e-Invoice for the same. e-Invoice system generates e-Invoice only for the transactions with current date or the backdated ones based on your business turnover.
  3. Drill down to the transaction with reason for rejection as the document date should not be future date.
  4. If you want to generate e-invoice for today’s date or past date, then press F2 and change the date to today’s date or past date, as needed.
  5. Press Ctrl+A to save.
The field Transin must be a string with a minimum length of 15 and a maximum length of 15.
The field Transin must match the regular expression ‘({0-9}{2}{A-Z 0-9}{13})’.
rejected-by-einvoice-system
This error occurs in the e-Invoice – Voucher Register report when the Transporter ID is not a valid ID of 15 digits. If you are using e-Invoice with e-Way Bill, you can also see this error in the e-Invoice report under the Rejected by e-Invoice System section. If you are using only e-Way Bill, then you can see this error in the e-Way Bill report under the Rejected by e-Way Bill System.
  1. In the e-Invoice – Voucher Register screen, select the particular voucher and press Enter to open it in the alteration mode.
  2. Set Provide GST/e-Way Bill/e-Invoice details to Yes.
    The Additional Details : Interstate Sales – Taxable screen appears.
    interstate-sales-taxable
  3. In the Transporter ID field, enter a valid ID of 15 digits.
  4. Save the voucher to resolve the error.
The field Transport document number must match the regular expression
Transporter Document Number is not as per the required format
Transporter document number in the e-Way Bill Details should follow the below validation
  1. Document number should be 15 characters
  2. Only capital letters are allowed
    Or
The field Legal Name must be a String with a minimum length of 3 and maximum length of 100
The field Legal Name is not as per the required format
Legal Name is the Entity registered Business with a specific Name. Under Mailing Name, ensure the Legal Name of the Business is provided to captured and should hold Min 3 to max 100 characters.
The JSON value could not be converted to System.Nullable`1[System.Int32]. Path: $.Data.EwbDtls.Distance | LineNumber: 0 | BytePositionInLine: 1969
The entered Pin to Pin Distance is invalid
This message is shown when both e-Invoice and e-Way Bill is generated. The distance provided in e-Way Bill details is invalid. Please check
https://ewaybillgst.gov.in/Others/P2PDistance.aspx
to validate the proper Distance
e-invoice option is not enabled for this GSTIN.
This happens because you have not registered for e-Invoicing with the necessary details on the e-Invoice portal.
While you might have already enabled the e-Invoicing in TallyPrime, you need to complete the enablement process on the e-Invoice portal.
  1. Open e-Invoice Enablement on your browser.
  2. Enter your GSTIN.
  3. Enter the OTP received on your registered mobile number to verify the GSTIN.
  4. Enter your Turnover and Financial Year.
  5. Click Submit.
    You will be registered for e-invoicing, and you can start generating e-invoices from TallyPrime.
Cancel the current e-Invoice generation request done in the e-invoice1 portal and send a new request for e-Invoice.
If you have generated the e-Invoice from e-Invoice2 portal, then this error occurs, as you can get IRN or cancel from TallyPrime only on the e-Invoice1 portal.
  1. Log in to the e-Invoice2 portal.
  2. select the respective transactions, and click Cancel e-Invoice.
  3. Select the reason for cancellation from the options.
  4. Click Submit
The e-invoice will be marked as Cancelled on the e-Invoice2 portal. You can then record a new transaction and generate e-Invoice from TallyPrime.
e-Way Bill Errors
Error Message Reason for Error Resolution
The distance between the pincodes given is too high or low.
The provided distance is incorrect. A difference of +/- 10% is allowed, and distance must fall within that range.
If you are using TallyPrime Release 5.0 and later,
  1. During voucher creation, set Provide e-Way Bill detailsto Yes. The e-Way Bill Details screen appears.
  2. Pin to pin distance as per portal can be left Blank and send request, so that from the portal this will auto fill the distance
If you are using TallyPrime Release 3.0 and later, then you can navigate to the link for the calculation of the distance from within the product.
  1. During voucher creation, set Provide e-Way Bill details to Yes.
    The
  2. Press Alt+L (Calculate Distance on Portal).
You will be redirected to the portal on which you can calculate the distance between the pincodes.
However, if you are using TallyPrime Release 2.1 or earlier, then you can open the following link on a browser and calculate the distance between the pincodes:
    The
Invoice Errors
Mismatch between HSN/SAC and Type of Supply.
This error occurs if you have entered an SAC code for goods or an HSN code for a service.
For goods, ensure that the HSN starts with 1-98 and the Type of Supply is Goods. For services, ensure that the SAC starts with 99 and the Type of Supply is Services.
In a Stock Item with HSN, if you have selected Service as Type of Supply, then,
  3. Drill down to the transaction with the above-mentioned error as the reason for rejection.
  4. Alter the Stock Item.
    1. Select the Stock Item and press Ctrl+Enter to open it in the alteration mode.
    2. Change the Type of Supply to Goods.
    3. Press Ctrl+A to save.
  5. Press Ctrl+A to re-save the transaction.
For a stock item with SAC created for services, if you have selected Goods as Type of Supply, then you can resolve the error in a similar way.
The field Location must be a string with a minimum length of 3 and a maximum length of 50.
This error occurs when the field Invoice bill from Place in the GST Details screen has less than 3 or more than 50 characters.
  1. Update Invoice bill from place.
    1. Press F11 (Company Feature) > Enable Goods and Service Tax (GST) > GST Details.
    2. In the GST details screen, update Invoice bill from place with values more than 3 and less than 50 characters.
  2. In the e-Invoice report, update the relevant transactions.
    3. Drill down to the transaction with the above-mentioned error as the reason for rejection and update the Place.
      1. Set Provide e-Invoice details to Yes.
      2. In the e-Invoice Details screen, check Place of the party.
      3. Press F12 (Configure) and set Provide Dispatch From Details to Yes, if the you are dispatching the goods from a different location.
        You can see that in the e-Invoice Details screen, the Place is updated as per the Invoice bill from place field in the GST Details screen.
    4. Press Ctrl+A to save.
  3. Press Ctrl+A to save the transaction.
  4. When prompted, press Y or Enter to generate e-Invoice for the transaction and enter your e-Invoice credentials.
Recipient should be SEZ for transaction SEZWOP.
This error occurs when you try to generate an e-Invoice for a party with Registration Type as SEZ but it has GSTIN/UIN of a Regular party.
  3. Drill down to the transaction with reason for rejection as Recipient should be Regular – SEZ for transaction SEZWOP.
  4. Alter the ledger in the transaction and configure it as Regular – SEZ.
    1. Select the ledger and press Ctrl+Enter to open the ledger in the alteration mode.
    2. In the GST Details screen, enter the GSTIN/UIN of the SEZ party.
    3. Press Ctrl+A to save the ledger.
GSTIN/UIN is not specified/invalid.
Cause 1: This error occurs when you try to generate an e-Invoice for a voucher in which the GSTIN/UIN for your party is either invalid or cancelled/suspended due to non-filing of GSTR-3B for 2 consecutive months.
Cause 2: This error occurs if all transactions are shown as rejected, which may happen when the company-level GSTIN/UIN of your company is incorrect or invalid.
Resolution 1:
  3. Drill down to the transaction with reason for rejection as GSTIN/UIN is not specified/invalid.
  4. Select the party ledger and press Ctrl+Enter to open the party ledger in the alteration mode.
  5. Press Alt+L (Fetch Details Using GSTIN/UIN) to validate the GSTIN/UIN for your party and update the valid GSTIN/UIN.
    If the GSTIN/UIN is invalid or wrong, then contact the party for valid GSTIN/UIN and proceed for e-Invoice generation.
    If GSTIN/UIN is cancelled or suspended, you will not be able to generate e-Invoice. Create Party ledgers using GSTIN/UIN to be able to generate e-Invoice.
  6. In the e-Invoice report, select Rejected by e-Invoice System and press Enter.
  7. Drill down to the transaction with reason for rejection as GSTIN/UIN is not specified/invalid.
  8. In the Party Details screen and update with correct GSTIN/UIN.
  9. Press Ctrl+A to save.
    generate-e-invoice
  10. When prompted, press Y or Enter to generate e-Invoice for the transaction and enter your e-Invoice credentials.
Resolution 2:
  1. Update Company GSTIN/UIN.
    1. Press F11 (Features) to open the Company Features Alteration screen.
    2. Set Enable Goods and Services Tax (GST) to Yes and update with the correct GSTIN/UIN.
    4. Select all transactions and press Alt+R (Marked as Resolved) so that transactions will get listed again under Pending for Exchange with e-Invoice System.
  3. Send the transactions to IRP for e-invoicing.
    1. Press Alt+Z (Exchange) > Send for e-Invoicing.
    2. In the Send for e-Invoicing screen, select the transactions and press S to send them to IRP for exchange.
      based-on-value
IRN details are not found
When trying to Get IRN info, this error is received when user has changed either Doc number, Doc Date and Doc Type post generating the IRN.
Don’t fire the same request simultaneously. This results in one request giving the error as ‘Duplicate IRN request’. Best way to avoid firing of IRN request repeatedly for the same request, is update in your system with IRN number when the response comes back. Next time check the IRN, if it is not there, then fire for IRN.
HSN code(s)-{0} is invalid
Wrong HSN code is being passed
Pl check the HSN code being passed and cross-check the correctness of HSN code on e-invoice portal. Still, if you feel it is correct, then please send the details to the helpdesk for verification at e-invoice system side.
Verify the details from below link
https://services.gst.gov.in/services/searchhsnsac
Combination of goods and service items are not allowed for inter state transaction with POS same as the supplier state
Items list has entries for both goods and services for inter state transaction
Items of both goods and services are not allowed in same invoice for inter state transaction
Supplier GSTIN state code does not match with the state code passed in supplier details
The state code passed and first two digits of the GSTIN passed in the Supplier details do not match
In the Supplier details, first two digits of the GSTIN should match the state code passed. Tally maps the State code against each state internally. In case user has created any state manually and are used, the said error triggers. Select the State from the given list of States.
Recipient GSTIN state code does not match with the state code passed in recipient details
The state code passed and first two digits of the GSTIN passed in the Recipient details do not match.
In the Recipient details, first two digits of the GSTIN should match the state code passed. Tally maps the State Code against each state internally. In case user has created any state manually and are used, the said error triggers. Select the State from the given list of States.
IRN details cannot be provided as it is generated more than {0} days prior
When trying to Get IRN info, this error is received when user has tried getting IRN info after 3 days.
Note: Currently e-Invoice support for getting IRN info is limited to 3 days from day of Generation. This can be changed by NIC in the future.
Vital Errors
GSTIN is inactive or cancelled by department or tax payer .
Invalid Gstin
Enrolled Transporter not allowed this site
The user who is not registered with GSTN but enrolled as transporter in E Way Bill portal is trying to login to eInvoice system
This is not allowed
Invalid From Pincode or To Pincode
PIN code passed is wrong
Pass the correct PIN code. Check the PIN code on the portal using the below link
https://einvoice1.gst.gov.in/Others/MasterCodes
Select Pincodes from the available radio buttons.
Select State Name, provide Captcha and click on Go to get the list of Pincodes
const searchInput = document.getElementById(“searchInput”); const searchContainer = document.getElementById(“searchContainer”); const searchRect = searchInput.getBoundingClientRect(); searchInput.addEventListener(“keyup”, searchShortcut); const brTag = “”; document.addEventListener(‘scroll’, scrollFunction); window.addEventListener(“resize”, scrollFunction); //function to make the searchbox stick to the top when scrolled function scrollFunction() { const tables = document.getElementsByClassName(“TallyGreen”); const heightAdjust = document.getElementById(“heightAdjust”); let tableWidth = 0; //loopthrough all the tables and find out which is the widest to set the width of the search box for (table of tables) { if (table.clientWidth > tableWidth) tableWidth = table.clientWidth; } //if all the table width is 0 that means no table is visible or else set the width to the visible one. if (tableWidth > 0) tableWidth = tableWidth + ‘px’; else if (tableWidth == 0) tableWidth = ‘100%’; //detect for the change in the header class which occurs after the scroll and apply the changes if (document.getElementsByClassName(“after-scroll-wrap”).length > 0) { // if (document.documentElement.scrollTop > 150) { searchContainer.className = ‘searchContainerScroll’; searchContainer.style.width = tableWidth; heightAdjust.style.height = “150px” } else { searchContainer.className = ‘searchContainer’; searchContainer.style.width = tableWidth; heightAdjust.style.height = “0px”; } } function searchShortcut(e) { const inputTag = e.target; const filter = inputTag.value.toUpperCase(); const filterArray = filter.split(‘ ‘); const canvas = inputTag.parentElement.parentElement; const tables = canvas.getElementsByTagName(“tbody”); const rightNav = document.getElementsByClassName(“ez-toc-list ez-toc-list-level-1”)[0]; let resultsCount = 0; // Loop through all the tables for (const table of tables) { tableRows = table.getElementsByTagName(“tr”); const tParent = table.parentElement; let matchFoundInTable = false; // set the table height to auto and capture the height attribute to set it back later if (filter.length > 0) { if (tParent.style.height != “auto”) tParent.setAttribute(“height-data”, tParent.style.height); tParent.style.height = “auto”; } else { tParent.style.height = tParent.getAttribute(“height-data”); } // Loop through the Rows of each Table for (const tableRow of tableRows) { let matchFound = false; let notHeader; // get the value of each cells in the table const tableCells = tableRow.getElementsByTagName(“td”); let content = “”; // put the entire content of the row into one string to check if the row has any match for (const tableCell of tableCells) { content = content + ” ” + (tableCell.innerText || tableCell.textContent); } //check for any matches in the entire row using “AND” logic to make sure the row has all the words let matchFoundInRow = (checkForMatches(filter, content).And) ? true : false; if (content.split(‘ ‘).length > 1) { // find out if it is not a header row notHeader = (content.split(‘ ‘)[1].slice(0, 6) != “Action”) ? true : false; // make sure there is a match and it is not a header if (matchFoundInRow && notHeader) { // if it is a single cell description in a row then hide it else make it visible if (tableCells.length == 1 && filter.length > 0) { tableRow.style.display = “none”; } else if (tableCells.length > 1) { tableRow.style.display = “”; } // loop through each cell in a row for (const tableCell of tableCells) { const cellValue = tableCell.innerText || tableCell.textContent; const cellIndex = cellValue.toUpperCase().indexOf(filter); // find out if the cell has matching value with the input and it is not a single cell description if (matchFoundInRow && tableCells.length > 1) { // if (tableCells.length > 1) { // check if the cell has more sub elements checkForChildren(tableCell, filter); // use the below variables later below, which determine whether there is a match in the row matchFoundInTable = true; matchFound = true; } else { // run the below function anyways. check the function for more details if (tableCells.length > 1) checkForChildren(tableCell, filter) } } } } // if a match is found inside one of the cells then make the row visible if (matchFound && tableCells.length > 1) { tableRow.style.display = “”; // count the number of times a match is found to display at the top resultsCount++; // else hide the row unless its not a header } else if (notHeader) { tableRow.style.display = “none”; } if (filter.length == 0 && tableCells.length == 1) tableRow.style.display = “”; } // if no results are found in the entire table then hide the table if (!matchFoundInTable) { tParent.style.display = “none”; tParent.previousElementSibling.style.display = “none”; // rightNav.style.display = “none”; } else { tParent.style.display = “”; tParent.previousElementSibling.style.display = “”; // rightNav.style.display = “”; } } // check if there is an element exists which displays the number of results let checkNoOfResults = document.getElementById(“noOfResults”); if (!checkNoOfResults) { // if it doesn’t exist then create one const noOfResults = document.createElement(“p”); noOfResults.id = “noOfResults”; noOfResults.style = “font-size: 14px; font-weight: 400″; checkNoOfResults = noOfResults; } // show the number of results found if (resultsCount > 1) checkNoOfResults.innerText = resultsCount + ” results found.”; else if (resultsCount == 1) checkNoOfResults.innerText = resultsCount + ” result found.”; else if (resultsCount == 0) checkNoOfResults.innerText = “No results found.”; // checkNoOfResults.innerText = (resultsCount > 1) ? resultsCount + ” results found.” : resultsCount + ” result found.”; inputTag.parentElement.insertBefore(checkNoOfResults, inputTag.nextElementSibling); // if everything from the input is deleted then remove the no of results if (filter.length == 0) checkNoOfResults.remove(); scrollFunction(); } // function to check for sub-elements if there are any (this is to handle the cells which has bullet points and multiple lines with br tag) function checkForChildren(element, filter) { const count = element.childElementCount; let brExists = false, bulletList = false, multiplePTag = false; //check for specific tags to determine the how to handle the content for (const child of element.children) { if (child.nodeName == “BR”) brExists = true; if (child.nodeName == “UL”) bulletList = true; if (child.nodeName == “P”) multiplePTag = true; } if (brExists) highlightWithBR(element, filter) //if there is bullet list then loop through each list item and highlight the text else if (bulletList) { for (const child of element.children) { if (child.nodeName == “P”) highlightText(child, filter) if (child.nodeName == “UL”) { for (const item of child.children) { highlightText(item, filter) } } } } else if (multiplePTag) { for (const child of element.children) { highlightText(child, filter) } } else highlightText(element, filter) } function highlightWithBR(element, filter) { // split the HTML with br tags const highlightable = element.innerHTML.split(brTag); let cellParts = []; for (child of highlightable) { const dummyTag = document.createElement(“p”); dummyTag.innerHTML = child; // highlight the elements seperatly and put them together into an array cellParts.push(highlightText(dummyTag, filter)); } // combine the array by adding a br tag back and then put that inside the elements HTML element.innerHTML = cellParts.join(brTag); } function generateID() { return Math.random().toString(36).replace(/[^a-z]+/g, ”).substr(2, 10); } function highlightText(tableCell, filter) { const cellValue = tableCell.innerText || tableCell.textContent; const cellIndex = cellValue.toUpperCase().indexOf(filter); const splitStrings = filter.split(‘ ‘); // remove if there is any duplication of words to avoid errors const filterStrings = splitStrings.filter((c, index) => { return splitStrings.indexOf(c) === index; }); let returnHTML; // check for matches in the cell with the “OR” logic since we have already filtered the row with “AND” logic. const matchFound = (checkForMatches(filter, cellValue).Or) ? true : false; let breakPoints = {}; let newPoints = []; if (matchFound) { breakPoints = {}; let stringCount = 0; // check for breakpoints wherever every match for every word starts and ends for (const filterString of filterStrings) { if (filterString.length > 0) { breakPoints[filterString] = findAllMatches(cellValue, filterString); stringCount++; } } // use the breakpoints to ignore any repeatition of highlight action to avoid errors for (let i = stringCount – 1; i >= 1; i–) { const validateStrings = breakPoints[filterStrings[i]] for (let k = 0; k = 0; j–) { const interruptStrings = breakPoints[filterStrings[j]] for (const interruptString of interruptStrings) { try { // capture the places wherever there is an overlap of matches if (validateStrings[k].firstIndex >= interruptString.firstIndex && validateStrings[k].firstIndex { return y.firstIndex – x.firstIndex; }) // returnHTML = tableCell.innerHTML returnHTML = divideAndHighlight(tableCell, pointsArray) tableCell.innerHTML = returnHTML; } else { // if there is no match found then get the plain text and put it inside as HTML (this will remove any existing highlight from it) returnHTML = cellValue; tableCell.innerHTML = cellValue; } // return the html (this is used in highlightWithBR function) return returnHTML; } function findAllMatches(content, filter) { const index = content.toUpperCase().indexOf(filter); let breakPoints = []; if (index > -1) { let firstIndex = index; let secondIndex = index + filter.length; let secondMatch; let count = 0; do { breakPoints.push({ ‘firstIndex’: firstIndex, ‘secondIndex’: filter.length, ‘stringID’: generateID() }); const secondPart = content.slice(secondIndex, content.length); secondMatch = secondPart.toUpperCase().indexOf(filter); count++; if (secondMatch > -1) { secondMatch = secondMatch + secondIndex; firstIndex = secondMatch; secondIndex = secondMatch + filter.length; } } while (secondMatch > -1); } return breakPoints; } function checkForMatches(filterString, content) { let matchCount = 0; let filterIndexArray = []; const filterArray = filterString.split(‘ ‘); let matchFound = { ‘And’: false, ‘Or’: false } for (const filterString of filterArray) { const index = content.toUpperCase().indexOf(filterString); filterIndexArray.push(index); if (index > -1) { matchCount++; } } if (filterArray.length == matchCount) matchFound.And = true; if (matchCount > 0) matchFound.Or = true; return matchFound; } function divideAndHighlight(tableCell, breakPoints) { const textContent = tableCell.innerText || tableCell.textContent; let htmlContent = textContent; i = 0; for (const breakPoint of breakPoints) { const first = breakPoint.firstIndex, second = breakPoint.secondIndex, index = breakPoint.stringCount; const part1 = htmlContent.slice(0, first); const part2 = htmlContent.slice(first, first + second); const part3 = htmlContent.slice(first + second, htmlContent.length); const highlightTag = (part2.length > 0) ? “” + part2 + “” : “”; htmlContent = part1 + highlightTag + part3; i++; } return htmlContent; }
