Writing Regular Expressions
A regular expression is a precise pattern that provides a very efficient way to specify and recognize strings of text. A combination of various characters along with the text to be searched for generates a regular expression.
TallyPrime Developer  uses regular expression to search for text based on specified patterns. These patterns are a combination of special characters and the text that needs to be searched for.
Some examples are given in the table below:
Character
Description
Example
Used to match the start of a line
^Local
This expression will search for all lines that start with Local
Used to match the end of a line
$Tally
This expression will search for all lines that end with Tally
Used to match or replace a Single Character
F.rm
This expression will search for all terms which start with F, have one character in the middle and end with rm
Searches for zero or more occurrences of the preceding character
Lo*cal
This expression will search for Lcal, Local, Loocal, Looocal…
Searches for one or more occurrences of the preceding character
Lo+cal
This expression will search for all terms Local, Loocal, Looocal…..
\x
Used to search for a character which otherwise may have another meaning
This expression will search for locations where ‘[‘ is present.
Used to match the start of a word
\<Ad
This expression will search for all terms that begin with Ad
Used to match the end of a word
\>ed
This expression is used for all terms that end with ed
Used to denote the start of a region for tagging a match
Used to denote the end of a region for tagging a match
Denotes a set of possible character matches
[A-z]
It will search for terms with characters between a to z
Used to indicate complement of a set of characters
[^A-d]
lt will not search for terms with characters between a to d
\d
Used to match a digit
Tally\(\d+\)
It will search for terms with a combination of text and numbers like Tally1, Tally512
\s
Used to match a white space character
Tally\s
It will search for terms with Tally and a line feed character after it like space or tab
Combination of Characters
To make a search more refined, we use a combination of characters. Any of the characters given above can be used in conjunction with each other to get a thoroughly enhanced output. Given below are a few examples to explain how this can be done.
Regular Expression
Result
^Tally\([abc]\)
This will search for terms which start at the beginning of the line and consist of Tallya, Tallyb or Tallyc.
Tal*y\(\d+\)
This will search for terms which have zero or more occurrences of l between a and y and any digits after the text.
This will search for lines containing only a single character.
^Pa?
This will search for any term which has a P OR Pa at the beginning of the line.
From the above examples we can see that regular expression is the term used to describe a codified method of searching which enables fast and responsive searches.
