Extract Data into MS Word Using ODBC in TallyPrime
You can extract the master data from TallyPrime to MS Word using ODBC and share that data with your customers and stakeholders. The steps vary slightly depending on your Word version, but the process begins by enabling ODBC in TallyPrime and then using Mail Merge to format and filter the data for printing or sharing.
Enable ODBC in TallyPrime
  1. Press Alt+Z (Exchange) > Configure.
  2. Under Data Synchronisation, select Client/Server configuration and press Enter.
    The Client/Server configuration screen appears.
  3. Enable ODBC: Yes.
    Ensure that the Port is as applicable to your license server.
Extract Data to MS Word 2007/2010 Using ODBC
Ensure that you have enabled ODBC in TallyPrime.
Step 1: Initiate document creation
  1. Click Mailings > Start Mail Merge > Step by Step Mail Merge Wizard.
    MS Word Mail Merge Wizard
    The Mail Merge appears on the right-hand side.
  2. Select document type: Labels.
  3. Click Next: Starting document.
    MS Word - Mail Merge Wizard on the Right-hand Side
Step 2: Apply formatting options, as applicable.
  1. Click Next: Select recipients.
    Select Recipients in Mail Merge in MS Word for Formatting
    The Label Options window appears.
  2. Select Product number:
    1. In MS Word 7, select Business Card and click OK.
      Product Number Business Card - Mail Merge in MS Word 7
    2. In MS Word 10, select based on your preference, for instance, European Size, and click OK.
      Product Number European Size - MS Word 2003
Step 3: Select the source of data.
  1. Click Next: Arrange your labels.
    Arrange Your Labels - MS Word - Mail Merge Using ODBC in TallyPrime
    The Select Data Source window appears.
  2. Click New Source.
    Click New Source in the Select Data Source Window of the Mail Merge Wizard in MS Word
    The Data Connection Wizard window appears.
  3. Select ODBC DSN and click Next.
    Data Connect Wizard Mail - Merge in MS Word (ODBC in TallyPrime)
    The Data Connection Wizard window starts displaying the list of ODBC data sources as shown below.
  4. Select the Tally ODBC data source with the appropriate port number.
    Select TallyODBC with Appropriate Port Number in Mail Merge Data Source (ODBC in TallyPrime)
    Note: If multiple data sources of Tally are listed, then you can check the appropriate port number in TallyPrime.
    In TallyPrime, press F1 (Help) > Settings > License > Manage License.
    The License Information screen appears, and you can identify the port number mentioned under the label Tally Gateway Server.
Step 4: Select data that needs to be extracted.
  1. Select the master, for instance, Ledger, StockItem, CostCategory, as applicable and click Next.
    Select Data Type - Master - MS Word's Mail Merge for Label Printing (ODBC in TallyPrime)
    The Data Connection Wizard window with File Name appears as shown below.
    Data Connection Window with File Name in MS Word's Mail Merge
  2. Click Finish.
    The Data Link Properties window appears.
Step 5: Test the connection
  1. Click Connection.
  2. Specify the source of data: Use data source name.
  3. From the list, select TallyODBC with the appropriate port number.
  4. Click Test Connection.
    Test the Connect of Mail Merge in Word File with Tally ODBC
    A test connection success message appears as shown below.
    Test Connection Success Message
  5. Click OK on the Test connection succeeded message sub-screen.
  6. Click OK to save the Data Link Properties
    The Mail Merge Recipients Window appears.
Step 6: Filter and sort the data, as required
  1. Click Sort.
    The Filter and Sort window appears.
  2. Click Filter Records.
  3. Field: $Parent.
  4. Comparison: Equal to.
  5. Compare to: type Sundry Debtors.
  6. In the next row, select the Or option to add more filters.
  7. Select appropriate options under Field and Comparison and under Compare to: type Sundry Creditors.
    Filter and Sort Data in Mail Merge - MS Word
  8. Click OK and the filters will be applied.
Step 7: Select options for label printing, as applicable
  1. In the Mailings tab of the MS Word file, click Insert Merge Field and select MailingName from the dropdown list.
    Insert Merge Field Mailings Tab - MS Word
  2. The MailingName field will appear in the first line of the first label as shown below.
    Mailing Name Copied for Label Printing with Mail Merge Using ODBC in TallyPrime
  3. Press Enter to bring the cursor to the next line.
  4. Select other fields such as M_Address1, M_Address2, M_Address3, M_Address4, PinCode, and StateName, as applicable.
    More Labels Copied for Label Printing Using ODBC in TallyPrime
  5. Click Next: Arrange your labels.
  6. In the Mail Merge Wizard, under Replicate labels, click Update all labels.
    The updated screen after label printing appears as shown below.
    Labels Printed Using Mail Merge Wizard - MS Word
Step 8: Save the document after label printing with mail merger
  1. Click Next: Preview your labels.
    The preview of the labels appears as shown below.
    Preview After Label Printing Using ODBC in TallyPrime
  2. Click Next: Complete the Merge
  3. Click Previous: Preview your labels, only if you want to preview the labels again.
  4. Press Ctrl+S to save the document.
Follow the above-mentioned steps to extract the required data with ease and use the data effectively for various purposes such as mailing lists, address labels, or business correspondence.
Extract Data to MS Word 2003 Using ODBC
  1. Click Tools > Letters and Mailings > Mail Merge.
    The Mail Merge task pane appears as shown below.
    Mail Merge in MS Word 2003 Using ODBC in TallyPrime
    1. Under Change document layout, click Label options.
      The Label Options screen appears.
    2. Under Product number, select the product number with the text Label, as required and click OK.
      Subsequently, Use the current document gets selected.
    1. Click Next: Select Recipients.
      Use an existing list is selected by default. Retain the selection.
    2. Click Browse.
    3. Click New Source.
      Select Data Source - Mail Merge in MS Word 2003
      The Data Connection Wizard appears.
    4. Select the required data source as shown below and click Next.
      Select Data Source Mail Merge - MS Word 2003 - ODBC in TallyPrime
      The Connect to ODBC Data Source appears.
    5. Under ODBC data sources, select the appropriate ODBC data source as shown below and click Next.
      ODBC Data Source Selection Mail Merge - MS Word 2003 - ODBC in TallyPrime
  1. Select the required master – Ledger, StockGroup, StockCategory, or any other, as per your requirement and click Next.
    Select Master - ODBC Data Connection Wizard
  2. Click Finish.
  3. Select the required data source from the list of data sources displayed.
  4. Click the Connection tab.
  5. Click the Use data source name checkbox.
  6. Click the dropdown list and select the required data source.
    The name of the catalog is displayed in Enter the initial catalog to use as shown below.
    Enter the Initial Catalog to Use Mail Merge in MS Word 2003
  1. Click Test Connection.
    A test connection success message appears.
  2. Click OK on the success message.
  3. Click OK in Data Link Connection.
    The Mail Merge Recipients appears.
Step 6: Filter and sort data, as required
  1. Click the dropdown list box.
    Mail Merge Recipients - Filter Data Using Dropdown (Mail Merge Using ODBC in TallyPrime)
    The list displaying the Filters appears.
  2. Select Advanced.
    Mail Merge Recipients - Applying Advanced Filters
    The Filter and Sort screen appears.
  3. Click the Filter Records tab.
  4. Click the Field drop-down list and select $Parent.
  5. Click Comparison and select Equal To.
  6. In Compare To, enter Sundry Creditors or Sundry Debtors, as required.
    Data Sorted and Filtered - Mail Merge - MS Word 2003
  7. Click OK.
    A sample Mail Merge Recipients window with the filtered and sorted data appears as shown below.
    Mail Merge Recipients Window with Data Sorted and Filtered
  8. Click OK.
  1. Click Insert Merge Fields.
    Insert Merge Fields - Mail Merge - MS Word 2003
    The Insert Merge Fields window with the Database Fields checked by default appears.
  2. From the list of Fields displayed, select the required field.
  3. Select other fields from the list, as per your requirement.
    Insert Merge Field in Mail Merge - MS Word 2003
    The address fields will start appearing as labels.
  4. Arrange the address fields, as per your requirement.
  6. Under the section Replicate labels, click Update all labels.
    A sample image with the updated labels will appear as shown below.
    Updated Labels - Mail Merge in MS Word 2003 Using ODBC in TallyPrime
  1. Click Preview your labels.
    The preview of the labels with The Company Name along with the Address in each slot appears.
    Preview - Label Printing with Mail Merge Using ODBC in TallyPrime
  2. Click >> to move to the next set of records or click << to move to the previous set of records.
  3. Click Next: Complete the Merge.
  4. Click Print.
    The Merge to Printer dialog box appears.
By default, you can print all the available records or provide the record number if you want to print the label of a selected party in the Current Record field. You may also print a subset of the available records by providing the starting record number in the From field and the ending record number in the To field.
