TallyPrime comes with a set of connected capabilities that take care of the busywork — data entry, backups, GST filing, banking and remote access. Pick one below to see how it works.
TallyIra
Meet TallyIra — it does your data entry, you stay in control.
Scan or upload bills and TallyIra reads them, drafts the vouchers, and flags anything that needs a second look. You review and approve — nothing posts on its own.
Scan or import invoices from your phone or desktop
AI extracts party, amount, GST & line items automatically
Bulk draft vouchers in minutes — saves ~80% of manual entry time
You review and approve every entry before it posts to TallyPrime
TallyDrive quietly backs up your company data to the cloud on the schedule you choose, so you stay compliant and are never more than a few clicks from a full recovery.
Automated daily, weekly, or monthly backups — no manual step
Helps you meet the Rule 46(8) requirement for daily electronic backups
Smart compression shrinks backup size by up to 10×
Restore any company to any saved version in a few clicks
Up to 3 GB free storage on multi-user TallyPrime, 1 GB on single-user
Meet Connected GST — file GST without leaving TallyPrime.
Connected GST links TallyPrime directly to the GST portal, so you can upload returns, reconcile purchases, and verify GSTINs without juggling JSON files or a second login.
Upload GSTR-1 straight from TallyPrime — no manual JSON export
One-click reconciliation across GSTR-1, 2A and 2B
Auto-fetch verified GSTIN details straight from GSTN
Download 2B data and reconcile purchases without visiting the portal
Meet Connected Banking — your bank, inside TallyPrime.
Connected Banking links your bank accounts directly into TallyPrime, so balances, statements, payments and reconciliation all happen in one place — no separate net-banking logins.
Reconcile transactions up to 70% faster, with automatic duplicate detection
Check real-time balances without leaving TallyPrime
Fetch bank statements on demand
Make secure payments directly from TallyPrime
Works with Axis, SBI, ICICI and Kotak Mahindra (TallyPrime 6.0+)
