Keep Your Books in Sync with Bank | Bank Reconciliation in TallyPrime
Bank reconciliation in TallyPrime ensures that your books match the actual transactions recorded by the bank. It helps you detect discrepancies between the company’s records and the bank statement, such as missed entries, duplicate transactions, or bank charges. Reconciled books are cleaner and more transparent, making audits smoother.
With TallyPrime, managing bank reconciliation becomes seamless and efficient. You can import bank statements in Excel or CSV format from over 145 banks, allowing automatic linking and reconciliation of transactions with your books. The automatic reconciliation reduces manual work and errors.
You can record your payments and receipts based on transactions in your bank statement.
What’s more, TallyPrime offers a wide range of reports:
  • Banking Activities gives you a brief overview with the counts of transactions Available in Books and Available in Bank.
  • Bank Reconciliation Summary contains the counts of transactions in all sections along with the Expected Bank Balance.
  • Bank Reconciliation report has all the facility to reconcile your transactions.
    You can refer to unreconciled and reconciled transactions and take actions, as needed.
Start Bank Reconciliation and Add Transactions Prior to That
You can start reconciling your transactions from any date. You just need to specify the Reconciliation Beginning Date in the bank ledger.
With the Opening BRS report, where you can add transactions recorded before the Reconciliation Beginning Date and still unreconciled.
Import Bank Statements to TallyPrime
You can import bank entries and use them to auto-reconcile book transactions with bank entries or auto-create vouchers using the imported bank entries.
Automatic Bank Reconciliation Transactions
If you create vouchers manually in TallyPrime, then just import your Bank Statements and start matching book transactions with bank entries using a variety of flexibilities provided for Bank Reconciliation.
Prerequisites for Using Automatic Bank Reconciliation
To start reconciling your transactions in TallyPrime, you need:
  • TallyPrime Release 6.0 or later releases.
  • Bank Statements in Excel or CSV format that you can import.
    You can import Bank Statements for more than 145 banks.
Automatic Bank Reconciliation flexibilities
After importing the Bank Statement, you can:
Automatic bank reconciliation in TallyPrime reduces manual errors with statement-based approach. Hence, you are always audit-ready.
Reconcile Transactions Manually
TallyPrime gives you the flexibility to reconcile your transactions manually, if you follow that method in your business.
You can enter Bank Date against each transactions and reconcile them manually.
